简介
If your Lenovo ThinkPad X1 Gen 1 Extreme (model number 20MF-000LUS used in this guide) is overheating or making clicking noises, use this guide to remove the fan.
While this laptop has been noted to get quite hot and loud, this should typically only occur when charging or using high intensity applications. The laptop should not be overheating when idle.
Keep in mind that an entire replacement of the fan may not be necessary, as the problem could potentially be built up dust or a foreign object. If this is the case, removing the fan and cleaning it out with compressed air could solve the issue.
你所需要的
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
Use tweezers to peel the plastic cover off the connector.
Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
另外一个人完成了本指南。
