简介
This guide will lead you through the steps to replace the display on the Lenovo ThinkPad X1 Extreme Generation 1. The display allows the user to see how they interact with the computer and may get damaged or worn down.
The removal of the display requires you to first remove the battery, then proceed to remove the hinge covering, take off the display cover, and detach it from the motherboard. Make sure the device is turned off before you begin these steps.
你所需要的
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
Use tweezers to peel the plastic cover off the connector.
Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
Gently take off the cover of the hinge of the computer with a combination of the opening tool and your hands.
另外一个人完成了本指南。
