跳转到主内容
Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement
你所需要的
  1. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 2 中的图像 2,2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Battery: 步骤 3 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
  4. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 4 中的图像 1,1
    • Take out the battery by lifting it from the top edge of the laptop, and then pulling away from the motherboard.
  5. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Fingerprint Scanner: 步骤 5 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Fingerprint Scanner: 步骤 5 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the 2mm screw that secures the cover of the fingerprint scanner.
  6. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 6 中的图像 1,1
    • Remove the cover by grabbing it and gently pulling up and to the left.
  7. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 7 中的图像 2,2
    • Use a nylon spudger to lift up the black bar that secures the cable.
    • Disconnect the ribbon cable from the fingerprint scanner by pulling the cable directly out.
  8. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Touchpad: 步骤 8 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Touchpad: 步骤 8 中的图像 2,2
    • Use a spudger to peel back the black adhesive pad.
    • Be gentle; the black adhesive pad is delicate and may rip.
  9. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 9 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 9 中的图像 2,2
    • Lift the lever that secures the cable.
    • Pull the cable out to disconnect the ribbon cable that connects to the touchpad.
    • This is the same procedure for removing most of the ribbon cables.
  10. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 10 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 10 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the four 1mm screws that secure the touchpad to the laptop.
  11. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 11 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: 步骤 11 中的图像 2,2
    • Once the screws are removed, the touchpad can be removed.
    • The touchpad may even fall out once the screws are removed. Be sure to secure the touchpad before it falls out.
结论
另外一个人完成了本指南。
Michael Megna
于01/23/20注册
1,265 声望
创作了7篇指南
团队
Cal Poly, Team S19-G4, White Winter 2020 Cal Poly, Team S19-G4, White Winter 2020 的会员
CPSU-WHITE-W20S19G4
3 名成员
创作了22篇指南
一条评论
Where do I get a new mouse pad after I have taken it off?
Jeremiah Gregg - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 28
过去 30 天: 105
总计 4,470
