跳转到主内容
Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement
你所需要的
  1. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: 步骤 2 中的图像 2,2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, SSD: 步骤 3 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, SSD: 步骤 3 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the single screw that secures the SSD to the motherboard.
  4. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the SSD by lifting it and pulling it out of the pins towards the battery of the laptop.
  5. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: 步骤 5 中的图像 2,2
    • Carefully peel the thermal pad off of the back of the SSD.
    • If the thermal pad is in good shape, you can reuse it by applying it to the replacement SSD.
结论
6等其他人完成本指南。
Michael Megna
于01/23/20注册
1,265 声望
创作了7篇指南
团队
Cal Poly, Team S19-G4, White Winter 2020 Cal Poly, Team S19-G4, White Winter 2020 的会员
CPSU-WHITE-W20S19G4
3 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 131
过去 30 天: 458
总计 19,670
