简介
In this guide, you will learn how to replace the fingerprint scanner in a Lenovo ThinkPad X1 Carbon 6th Gen. This may be necessary if your scanner is no longer reading your fingerprint. Before replacing your fingerprint scanner, try updating or reinstalling the fingerprint scanner drivers first. Be sure to power off your device and disconnect it from any power source before beginning.
你所需要的
Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
Use the Phillips #0 screwdriver to remove the 2mm screw that secures the cover of the fingerprint scanner.
另外一个人完成了本指南。
