跳转到主内容
Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink Replacement
你所需要的
  1. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: 步骤 4 中的图像 1,3 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: 步骤 4 中的图像 2,3 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: 步骤 4 中的图像 3,3
    • Use the Phillips #1 screwdriver to remove all five 1 mm screws holding the fan and heat sink down.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: 步骤 5 中的图像 2,2
    • Pick up the fan and heat sink and carefully and remove it.
结论
另外一个人完成了本指南。
团队
Gateway, Team 1-3, Saknee Fall 2021 Gateway, Team 1-3, Saknee Fall 2021 的会员
GCC-SAKNEE-F21S1G3
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 62
总计 2,053
