跳转到主内容
Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement
你所需要的
  1. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Battery: 步骤 4 中的图像 1,2 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, CMOS Battery: 步骤 6 中的图像 1,1
    • Once the battery is removed the CMOS battery will be exposed.
  7. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 步骤 7 中的图像 2,2
    • Disconnect the CMOS cable from the socket on the motherboard.
  8. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the CMOS battery.
结论
另外一个人完成了本指南。
团队
Gateway, Team 1-3, Saknee Fall 2021 Gateway, Team 1-3, Saknee Fall 2021 的会员
GCC-SAKNEE-F21S1G3
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 192
过去 30 天: 777
总计 19,512
