跳转到主内容
Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement
你所需要的
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: 步骤 3 中的图像 2,2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 步骤 5 中的图像 1,1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Touchpad: 步骤 6 中的图像 1,1
    • Remove the black ribbon cable connected to the touchpad.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 步骤 7 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the four 1.9 mm screws holding in the touchpad.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 步骤 8 中的图像 1,1
    • Remove the touchpad by opening the computer and letting it drop onto your hand.
结论
另外一个人完成了本指南。
Eevee Murdock
于01/23/20注册
1,086 声望
创作了6篇指南
团队
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020 的会员
CPSU-WHITE-W20S18G4
4 名成员
创作了7篇指南
2条评论
Even the weirder of their models is still amazingly engineered, this was so easy to do and finding parts - not only of the same model but compatible newer parts - was an absolute breeze! Was able to upgrade my laptop during my work lunchtime, and still have time to actually eat lunch!
Casey - 回复
Just to confirm - Thinkpad X1 Carbon Generation 3 touchpads are compatible with this model, and make for an amazing upgrade.
Casey - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 35
总计 1,705
