跳转到主内容
Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement
你所需要的
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: 步骤 3 中的图像 2,2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: 步骤 5 中的图像 1,1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: 步骤 6 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: 步骤 6 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the four 4.6mm screws holding the speakers.
    • Each speaker has 2 screws.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: 步骤 7 中的图像 2,2
    • Disconnect the wire running from the right speaker to the motherboard.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: 步骤 8 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: 步骤 8 中的图像 2,2
    • Remove the tape that is holding down the wire that connects the two speakers.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: 步骤 9 中的图像 1,1
    • Remove the speakers by lifting them directly upward.
结论
Eevee Murdock
于01/23/20注册
1,086 声望
创作了6篇指南
团队
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020 的会员
CPSU-WHITE-W20S18G4
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 15
总计 1,051
