跳转到主内容
Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement
你所需要的
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: 步骤 3 中的图像 2,2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 5 中的图像 1,1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Fan: 步骤 6 中的图像 1,1
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 7 中的图像 1,1
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 8 中的图像 1,1
    • Remove the fan by lifting it directly up.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: 步骤 9 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Disconnect all 10 of the ribbon cables attached to the motherboard.
  10. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 10 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 10 中的图像 2,2
    • Disconnect the wire connecting the motherboard to the speaker.
  11. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 11 中的图像 1,1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding the metal covering over the power jack prongs.
  12. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 12 中的图像 1,1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding down the Micro-SD card tray.
  13. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 13 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 13 中的图像 2,2
    • Un-tape the orange and blue wires from the motherboard.
  14. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 14 中的图像 1,1
    • Remove the black and grey wires from the cable comb on the motherboard.
  15. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 15 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 15 中的图像 2,2
    • Use a Phillips #1 screwdriver to unscrew the 3.7mm screw holding down the wifi card.
    • Remove the wifi card.
  16. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 16 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 步骤 16 中的图像 2,2
    • Carefully remove the motherboard by lifting it and pulling towards the left.
结论
4等其他人完成本指南。
Eevee Murdock
于01/23/20注册
1,086 声望
创作了6篇指南
团队
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020 的会员
CPSU-WHITE-W20S18G4
4 名成员
创作了9篇指南
2条评论
All going as described, until the final step trying to pull the motherboard out, and there is something still holding it in place. With a bit of a wiggle and pull, there is something about near the screw hole that was holding the wifi card down preventing the card from lifting there. Any clues?
Tim Ellison - 回复
Answering my own question: Removing the motherboard requires that you first pop the SIM card / MicroSD card holder out of the socket, otherwise it won’t lift out. Submitted an update to the guide to save others falling into the same trap.
Tim Ellison -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 39
总计 3,800
