跳转到主内容
Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement
你所需要的
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the battery by pulling it directly towards you.
结论
9等其他人完成本指南。
Eevee Murdock
于01/23/20注册
1,086 声望
创作了6篇指南
团队
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020 的会员
CPSU-WHITE-W20S18G4
4 名成员
创作了9篇指南
4条评论
iFixit replacement battery is rejected by X1 Carbon gen2 chassis as not-genuine/unauthorized. Is there some additional step to getting the battery to be recognized/allowed? Something in the BIOS? Or is the battery faulty?
lenovo_battery - 回复
Any comments from @ifixit?
Martin Optilon - 回复
Hi there! Thanks for bringing this to our attention. @lenovo_battery, sorry to hear you're having trouble with your battery. Please reach out directly to our customer support team by emailing support@ifixit.com.
Kristen Gismondi -
Hi,
Great guide. I found that my screw heads were a bit stripped and the #0 driver was too small and bounced too much. The #1 driver worked better for me. Thanks for promoting the repair revolution! - MiLo
milostudios - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 85
总计 4,916
