跳转到主内容
Lenovo ThinkPad W541 Touchpad Replacement
你所需要的
  1. Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: 步骤 1 中的图像 1,2 Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: 步骤 1 中的图像 2,2
    • Slide the clips to the left and right sides, remove the battery upwards.
    • Loosen two Phillips #00 screws and open the cover plate.
    • Remove four 9.0 mm Phillips #00 case screws.
    • Remove three 9.0 mm Phillips #00 screws circled with red in the second picture.
  2. Lenovo ThinkPad W541 Touchpad Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad W541 Touchpad Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad W541 Touchpad Replacement: 步骤 2 中的图像 3,3
    • Use the pry bar to push the keypad below the slot shown in the first picture and push it upward.
    • Loosen six Phillips #000 screws circled with red in the second picture, lift up the keyboard.
  3. Lenovo ThinkPad W541 Touchpad Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad W541 Touchpad Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad W541 Touchpad Replacement: 步骤 3 中的图像 3,3
    • Open the black clips according to the direction marked in the first picture and remove the cable.
    • Use a pry bar to pry open the black protective casing upwards.
    • Follow the direction shown in the third picture, open the black clips upwards and remove the cable.
  4. Lenovo ThinkPad W541 Touchpad Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad W541 Touchpad Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad W541 Touchpad Replacement: 步骤 4 中的图像 3,3
    • Remove the four 2.0 mm Phillips #000 screws circled with red in the first picture.
    • Carefully remove the metal tape shown in the second picture and paste it back on after replacing the new touchpad.
    • As shown in the third picture, remove the trackpad that needs to be replaced.
  5. Lenovo ThinkPad W541 Touchpad Replacement: 步骤 5 中的图像 1,1
    • You can replace your touchpad with a new one. To install your computer just follow this guide in reverse.
结论
Panaien Liu
于01/31/23注册
121 声望
撰写一个指南
团队
York University, Team P-5, Allen Winter 2023 York University, Team P-5, Allen Winter 2023 的会员
YORK-ALLEN-W23SPG5
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 370
