跳转到主内容
Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement
你所需要的
  1. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): 步骤 1 中的图像 1,2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): 步骤 1 中的图像 2,2
    • Turn your laptop over so the backplate is facing you.
    • Start with your Phillips #0 screwdriver and unscrew the 2 screws in each of the top corners of the backplate.
    • These screws should stay put on the backplate, and should not fall off.
  2. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 步骤 2 中的图像 2,2
    • With your Phillips #00 screwdriver, simply remove the one 3mm screw on the upper left side.
  3. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 步骤 3 中的图像 3,3
    • Remove the ODD by using a plastic opening tool to push the drive out of the side of the laptop.
    • Make sure to place the tool where we removed the screw holding the drive in place in Step 2.
  4. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 步骤 4 中的图像 1,1
    • Once the ODD has popped out, simply grab and pull out the drive bay.
结论
Isaac
于10/30/23注册
205 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024 的会员
UMASSD-SHADDIX-S24S4G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 17
总计 112
