跳转到主内容
Lenovo ThinkPad W540 Hard Drive Replacement
你所需要的
  1. Lenovo ThinkPad W540 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 Lenovo ThinkPad W540 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Flip the laptop to the bottom so the backplate is shown.
    • Use a Phillips #0 screwdriver to unscrew the 2 captive screws that secure the backplate.
    • These screws should hold on to the backplate even after removal. So, you shouldn't worry about losing them.
  2. Lenovo ThinkPad W540 Hard Drive Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad W540 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to unscrew the single 3 mm screw that secures the hard drive.
  3. Lenovo ThinkPad W540 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Lift up the bottom half of the hard drive at a 25 degree angle.
    • Simply pull out the hard drive.
  4. Lenovo ThinkPad W540 Hard Drive Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad W540 Hard Drive Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad W540 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Safely remove the plastic guard surrounding both the hard drive and ESD shielding.
  5. Lenovo ThinkPad W540 Hard Drive Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad W540 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Carefully removing the ESD shielding surrounding the hard drive.
    • Do not disregard the ESD shielding unless your new hard drive or SSD comes with its own shielding. Failure to do so will lead to severe damage to your device.
结论
另外一个人完成了本指南。
Kevin Dang
于10/30/23注册
333 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-2, Konn Fall 2023 UMass Dartmouth, Team 3-2, Konn Fall 2023 的会员
UMASSD-KONN-F23S3G2
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 122
