简介
This guide will show you how to replace broken speakers in a ThinkPad W520. Along the way, you will have a chance to upgrade or replace your RAM.
你所需要的
Use your left hand and push the unlock switch all the way to the right.
Use your right hand to push the battery.
Unscrew the two Phillips #0 screws.
The screws remain attached to the cover.
Lift up and remove the cover.
If your laptop has a dual-core processor any RAM installed here won't function.
Flip your laptop over and open the screen.
With your left thumb, grip the keyboard right below the blue "ThinkVantage" button. Use your other fingers as support only.
Using a spudger with your right hand, put pressure on one of the upper mouse buttons.
After your hands are in place, gently but firmly push towards the screen. The keyboard should move about 2 mm towards the screen.
If your computer has a dual-core processor, these are the RAM slots that will work.
Unscrew the Phillips #0 screw securing the hard drive cover.
The screw does not detach from the cover.
Remove the seven 13.75 mm Phillips #0 screws from the case.
Remove the 3.75 mm Phillips #0 screw from below where the hard drive used to be.
Remove the three 3.75 mm Phillips #0 screws from below where the battery used to be.
Before the top casing can be removed, there are two more things to do.
First, the ribbon cable that connects the trackpad to the motherboard needs to be removed.
Use a plastic opening tool to lift up the ZIF connector.
Pull the cable out of the connector.
The last thing to do before removing the top casing is taking out the dummy card in the ExpressCard 34 slot.
Flip the laptop so its resting on the back of the screen.
Using your thumb, press the plastic ExpressCard dummy into the case until you hear a click.
Let go and then pull out the card.
Using a spudger, start about an inch from the very left of the laptop.
Press the spudger into the edge of the casing.
Slide the spudger to your right, along the edge of the casing.
Once you reach the screen release mechanism, remove the spudger.
Put the spudger on the edge of the casing, about an inch from the very right of the laptop.
Gently push until you hear the clip release.
Set the laptop down on its base.
Slowly pull up the casing with both hands at the corners. There should be a few more clips that release.
Fully remove the casing.
Here you can see the left speaker, the right speaker, and the connector that both speakers attach to.
Left speaker
Right Speaker
Connector
We will start with the left speaker.
The left speaker is connected with the blue and white wire. The two wires should be stuck to each other.
Using a spudger and your hand as needed, gently remove the wire from all constraints.
The right speaker is connected with the black and red wires. The black and red wires should be stuck together.
First lift up the two pieces of black tape, but don't fully remove them.
Using a spudger and your hand as needed, gently free the black and red wire from all constraints.
Pass the speakers under any other wires that are restricting them.
The speakers are now free to be removed and replaced.
16等其他人完成本指南。
