跳转到主内容
Lenovo ThinkPad T580 Thermal Paste Replacement
你所需要的
  1. Lenovo ThinkPad T580 Thermal Paste Replacement, Opening the back panel.: 步骤 1 中的图像 1,3 Lenovo ThinkPad T580 Thermal Paste Replacement, Opening the back panel.: 步骤 1 中的图像 2,3 Lenovo ThinkPad T580 Thermal Paste Replacement, Opening the back panel.: 步骤 1 中的图像 3,3
    • Unscrew the 8 screws holding the back panel in place.
    • Remove the first battery by sliding the notches and pulling the battery outwards.
    • Use a prying tool to carefully release all the clips holding the panel in place.
  2. Lenovo ThinkPad T580 Thermal Paste Replacement, The insides.: 步骤 2 中的图像 1,1
    • It is recommended to disconnect the second battery too.
    • Unscrew the screws holding the CPU heatsink and disconnect the fan.
  3. Lenovo ThinkPad T580 Thermal Paste Replacement, Changing the thermal paste.: 步骤 3 中的图像 1,2 Lenovo ThinkPad T580 Thermal Paste Replacement, Changing the thermal paste.: 步骤 3 中的图像 2,2
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • You can also open the fan assembly to clean it better.
    • Last, put the heatsink back carefully and tighten the screws in order to ensure even pressure. Dont forget to plug in the fan cable.
  4. Lenovo ThinkPad T580 Thermal Paste Replacement, Upgrading the RAM and SSD (Optional): 步骤 4 中的图像 1,1
    • Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
    • Dont forget to plug in the second battery before closing the back panel!
结论
2等其他人完成本指南。
Simeon Brankov
于11/08/20注册
7,279 声望
创作了54篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 44
总计 883
