跳转到主内容
Lenovo ThinkPad T580 CMOS Battery Replacement
你所需要的
  1. Lenovo ThinkPad T580 CMOS Battery Replacement, External Battery: 步骤 1 中的图像 1,3 Lenovo ThinkPad T580 CMOS Battery Replacement, External Battery: 步骤 1 中的图像 2,3 Lenovo ThinkPad T580 CMOS Battery Replacement, External Battery: 步骤 1 中的图像 3,3
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 2 中的图像 3,3
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 3 中的图像 3,3
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 CMOS Battery Replacement, Bottom Case: 步骤 4 中的图像 1,2 Lenovo ThinkPad T580 CMOS Battery Replacement, Bottom Case: 步骤 4 中的图像 2,2
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 5 中的图像 3,3
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 6 中的图像 3,3
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 CMOS Battery Replacement, Internal Battery: 步骤 7 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 8 中的图像 1,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 8 中的图像 2,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 8 中的图像 3,3
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
  9. Lenovo ThinkPad T580 CMOS Battery Replacement, CMOS Battery: 步骤 9 中的图像 1,3 Lenovo ThinkPad T580 CMOS Battery Replacement, CMOS Battery: 步骤 9 中的图像 2,3 Lenovo ThinkPad T580 CMOS Battery Replacement, CMOS Battery: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Pull out the CMOS battery cable connector with a pair of blunt nose tweezers.
  10. Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 10 中的图像 1,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 10 中的图像 2,3 Lenovo ThinkPad T580 CMOS Battery Replacement: 步骤 10 中的图像 3,3
    • Using a spudger, pry the CMOS battery off of the motherboard.
    • A light adhesive holds the CMOS battery down to the motherboard. Be careful not to puncture the battery while prying it off.
    • Remove the CMOS battery.
结论
Austin Blakely
于03/11/19注册
19,855 声望
创作了53篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,895篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 37
总计 635
