跳转到主内容
Lenovo ThinkPad T570 SSD Replacement
你所需要的
  1. Lenovo ThinkPad T570 SSD Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo ThinkPad T570 SSD Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo ThinkPad T570 SSD Replacement, Battery: 步骤 1 中的图像 3,3
    • Switch the left latch to the left to unlock the battery.
    • While holding the right latch to the right, slide the battery away from the device.
  2. Lenovo ThinkPad T570 SSD Replacement, SSD: 步骤 2 中的图像 1,3 Lenovo ThinkPad T570 SSD Replacement, SSD: 步骤 2 中的图像 2,3 Lenovo ThinkPad T570 SSD Replacement, SSD: 步骤 2 中的图像 3,3
    • Loosen the seven captive screws on the back panel of the computer using a Phillips #0 screwdriver.
    • The screws are designed so they do not come out of the laptop base, so twist the screwdriver until they are completely loosened.
    • Remove the back panel.
  3. Lenovo ThinkPad T570 SSD Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad T570 SSD Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad T570 SSD Replacement: 步骤 3 中的图像 3,3
    • Pinch the black tab and pull it to the left and up to remove the SSD.
    • Flip the hinge upward and detach the piece that's connected to the SSD by pulling the tab to the left.
  4. Lenovo ThinkPad T570 SSD Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad T570 SSD Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws.
    • These screws are very small. Be mindful when removing them so that they do not get lost.
    • Remove the metal bracket.
    • Remove the SSD.
    • This device did not include an SSD.
结论
Rylee Hjorth
于09/04/24注册
277 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 58
总计 175
