跳转到主内容
Lenovo ThinkPad T560 SSD/Hard Drive Replacement
你所需要的
  1. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, SSD/Hard Drive: 步骤 3 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the 3.5mm screw securing the SSD/Hard Drive.
  4. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Pick up the SSD/Hard Drive and unplug it from the cable connecting the SSD/Hard Drive to the motherboard.
  5. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove SSD/Hard Drive case from the drive.
结论
2等其他人完成本指南。
Jackson Reynolds
于02/27/22注册
517 声望
创作了5篇指南
团队
Clemson, Team 1-3, Hunter Spring 2022 Clemson, Team 1-3, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S1G3
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 52
过去 30 天: 197
总计 4,314
