跳转到主内容
Lenovo ThinkPad T530 Hard Drive Replacement
你所需要的
  1. Lenovo ThinkPad T530 Hard Drive Replacement, Place your laptop upside down: 步骤 1 中的图像 1,2 Lenovo ThinkPad T530 Hard Drive Replacement, Place your laptop upside down: 步骤 1 中的图像 2,2
    • Ensure that the laptop is disconnected from the wall charger, and that the laptop is entirely powered off before following any of the steps below.
    • Flip your laptop upside down, so that the keyboard is facing down.
  2. Lenovo ThinkPad T530 Hard Drive Replacement, Unlock Battery: 步骤 2 中的图像 1,2 Lenovo ThinkPad T530 Hard Drive Replacement, Unlock Battery: 步骤 2 中的图像 2,2
    • Locate the latch located on the battery near the top of the laptop.
    • Using your finger, slide the latch to the right-most (Unlocked) position.
    • None of this should require an exhuberant amount of force.
  3. Lenovo ThinkPad T530 Hard Drive Replacement, Remove the Battery: 步骤 3 中的图像 1,2 Lenovo ThinkPad T530 Hard Drive Replacement, Remove the Battery: 步骤 3 中的图像 2,2
    • You can now pull the battery away from the laptop. When pulling the battery out, ensure to pull it out straight.
  4. Lenovo ThinkPad T530 Hard Drive Replacement, Opening Storage Drive Door: 步骤 4 中的图像 1,3 Lenovo ThinkPad T530 Hard Drive Replacement, Opening Storage Drive Door: 步骤 4 中的图像 2,3 Lenovo ThinkPad T530 Hard Drive Replacement, Opening Storage Drive Door: 步骤 4 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the bottom screw to unlock the storage drive cover.
    • Lift up the storage drive cover from the lip highlighted in orange. Put it aside.
  5. Lenovo ThinkPad T530 Hard Drive Replacement, Removing Storage Drive: 步骤 5 中的图像 1,2 Lenovo ThinkPad T530 Hard Drive Replacement, Removing Storage Drive: 步骤 5 中的图像 2,2
    • Pull the storage drive out of the slot from the tab.
    • Pull the drive at an angle, and not directly up as this could cause damage to the sata connector.
  6. Lenovo ThinkPad T530 Hard Drive Replacement, Removing Drive Spacers: 步骤 6 中的图像 1,2 Lenovo ThinkPad T530 Hard Drive Replacement, Removing Drive Spacers: 步骤 6 中的图像 2,2
    • Grab the rubber spacers highlighted in red, and pull them away from the drive.
  7. Lenovo ThinkPad T530 Hard Drive Replacement, Removing the Drive from the Caddy: 步骤 7 中的图像 1,2 Lenovo ThinkPad T530 Hard Drive Replacement, Removing the Drive from the Caddy: 步骤 7 中的图像 2,2
    • Using a Phillips #00 screwdriver, unscrew the four screws, two on each of the left, and right side of the drive.
结论
另外一个人完成了本指南。
Albert Stoynov
于09/11/23注册
1,255 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 44
总计 188
