跳转到主内容
Lenovo ThinkPad T530 External Battery Replacement
你所需要的
  1. Lenovo ThinkPad T530 External Battery Replacement, Place your laptop upside down: 步骤 1 中的图像 1,2 Lenovo ThinkPad T530 External Battery Replacement, Place your laptop upside down: 步骤 1 中的图像 2,2
    • Ensure that the laptop is disconnected from the wall charger, and that the laptop is entirely powered off before following any of the steps below.
    • Flip your laptop upside down, so that the keyboard is facing down.
  2. Lenovo ThinkPad T530 External Battery Replacement, Unlock Battery: 步骤 2 中的图像 1,2 Lenovo ThinkPad T530 External Battery Replacement, Unlock Battery: 步骤 2 中的图像 2,2
    • Locate the latch located on the battery near the top of the laptop.
    • Using your finger, slide the latch to the right-most (Unlocked) position.
    • None of this should require an exhuberant amount of force.
  3. Lenovo ThinkPad T530 External Battery Replacement, Remove the Battery: 步骤 3 中的图像 1,2 Lenovo ThinkPad T530 External Battery Replacement, Remove the Battery: 步骤 3 中的图像 2,2
    • You can now pull the battery away from the laptop. When pulling the battery out, ensure to pull it out straight.
结论
另外一个人完成了本指南。
Albert Stoynov
于09/11/23注册
1,255 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 132
