跳转到主内容
Lenovo ThinkPad T500 Speaker Replacement
你所需要的
  1. Lenovo ThinkPad T500 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
  2. Lenovo ThinkPad T500 Speaker Replacement: 步骤 2 中的图像 1,1
    • Lift the palm rest panel up.
    • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
  3. Lenovo ThinkPad T500 Speaker Replacement: 步骤 3 中的图像 1,1
    • Use the spudger to disconnect the ribbon cable.
  4. Lenovo ThinkPad T500 Speaker Replacement: 步骤 4 中的图像 1,1
    • With the panel disconnected, lift the keyboard.
    • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
  5. Lenovo ThinkPad T500 Speaker Replacement: 步骤 5 中的图像 1,1
    • Disconnect the ribbon cable with the spudger.
  6. Lenovo ThinkPad T500 Speaker Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad T500 Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the keyboard and the panel.
    • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
    • Disconnect the orange and blue cables next to the left side of the speaker cover.
  7. Lenovo ThinkPad T500 Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove the speaker cover by carefully pulling up and towards you.
  8. Lenovo ThinkPad T500 Speaker Replacement: 步骤 8 中的图像 1,1
    • Remove the four 3mm screws on the speakers with the Phillips #0 Screwdriver.
  9. Lenovo ThinkPad T500 Speaker Replacement: 步骤 9 中的图像 1,2 Lenovo ThinkPad T500 Speaker Replacement: 步骤 9 中的图像 2,2
    • Using the spudger, lift the tape over the right speaker's wires.
    • Although the right speaker is unscrewed, it can't be removed from the laptop yet!
  10. Lenovo ThinkPad T500 Speaker Replacement: 步骤 10 中的图像 1,2 Lenovo ThinkPad T500 Speaker Replacement: 步骤 10 中的图像 2,2
    • Detach the blue and orange cables from the left speaker's clamps.
  11. Lenovo ThinkPad T500 Speaker Replacement: 步骤 11 中的图像 1,3 Lenovo ThinkPad T500 Speaker Replacement: 步骤 11 中的图像 2,3 Lenovo ThinkPad T500 Speaker Replacement: 步骤 11 中的图像 3,3
    • Locate the plug in the middle of the laptop that connects both the left and right speakers.
    • Use the spudger to unplug the speaker wires.
  12. Lenovo ThinkPad T500 Speaker Replacement: 步骤 12 中的图像 1,1
    • Remove the speakers.
结论
nicO
于04/14/15注册
15,927 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了574篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 16
总计 1,210
