跳转到主内容
Lenovo ThinkPad T495s Trackpad Replacement
你所需要的
  1. Lenovo ThinkPad T495s Trackpad Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Do not begin until the laptop is unplugged and completely powered off.
    • Flip the laptop over to reveal the back panel of the laptop.
  2. Lenovo ThinkPad T495s Trackpad Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T495s Trackpad Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T495s Trackpad Replacement: 步骤 2 中的图像 3,3
    • Loosen the five 4.0 mm captive screws with a Phillips #1 screwdriver.
    • The screws will stay attached to the back cover as you lift it off.
  3. Lenovo ThinkPad T495s Trackpad Replacement, Battery: 步骤 3 中的图像 1,3 Lenovo ThinkPad T495s Trackpad Replacement, Battery: 步骤 3 中的图像 2,3 Lenovo ThinkPad T495s Trackpad Replacement, Battery: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to unplug the battery connection from the motherboard.
  4. Lenovo ThinkPad T495s Trackpad Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T495s Trackpad Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T495s Trackpad Replacement: 步骤 4 中的图像 3,3
    • Remove the five 4.5 mm screws with a Phillips #1 screwdriver.
    • There are plastic tabs at the bottom of the battery, so pull it slightly forward with your hands, toward the motherboard, before lifting straight up.
  5. Lenovo ThinkPad T495s Trackpad Replacement, Trackpad: 步骤 5 中的图像 1,3 Lenovo ThinkPad T495s Trackpad Replacement, Trackpad: 步骤 5 中的图像 2,3 Lenovo ThinkPad T495s Trackpad Replacement, Trackpad: 步骤 5 中的图像 3,3
    • Use the iFixit Opening Tool to flip up the small locking flap on the trackpad's one ZIF ribbon cable connection. The ribbon cable should easily release from its socket.
    • ZIF stands for Zero Insertion Force; if you're experiencing any resistance whatsoever during disconnection, double-check that the locking flaps are flipped up.
  6. Lenovo ThinkPad T495s Trackpad Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad T495s Trackpad Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad T495s Trackpad Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the four 2.2 mm screws from the trackpad.
  7. Lenovo ThinkPad T495s Trackpad Replacement: 步骤 7 中的图像 1,3 Lenovo ThinkPad T495s Trackpad Replacement: 步骤 7 中的图像 2,3 Lenovo ThinkPad T495s Trackpad Replacement: 步骤 7 中的图像 3,3
    • With the bottom of the laptop facing you, gently lift the laptop open until the trackpad drops out.
结论
Jessica Costa
于03/28/22注册
125 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-7, Petersen Spring 2022 UMass Dartmouth, Team 1-7, Petersen Spring 2022 的会员
UMASSD-PETERSEN-S22S1G7
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 64
总计 1,069
