跳转到主内容
Lenovo ThinkPad T495 Wi-Fi Card Replacement
你所需要的
  1. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Baseplate: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 1,3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 2,3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to lift the two coaxial cable connectors vertically, disconnecting them from the Wi-Fi card.
    • Use a Phillips #00 screwdriver to remove the 6 mm screw, causing the Wi-Fi card to pop up.
  4. Lenovo ThinkPad T495 Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad T495 Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Grip the Wi-Fi card between your fingers and pull it in the direction of the card, at a slight angle, until it releases from its port.
结论
Christian Taylor
于03/28/22注册
523 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-6, Petersen Spring 2022 UMass Dartmouth, Team 1-6, Petersen Spring 2022 的会员
UMASSD-PETERSEN-S22S1G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 27
总计 776
