简介
If your laptop won't connect to Wi-Fi, the issue could be because of a damaged or broken Wi-Fi card. This guide will cover the replacement of the Wi-Fi card in the Lenovo Thinkpad T495.
你所需要的
Use tweezers to lift the two coaxial cable connectors vertically, disconnecting them from the Wi-Fi card.
Use a Phillips #00 screwdriver to remove the 6 mm screw, causing the Wi-Fi card to pop up.
即将完成!
结论
