跳转到主内容
Lenovo ThinkPad T495 Speaker Replacement
你所需要的
  1. Lenovo ThinkPad T495 Speaker Replacement, Baseplate: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Speaker Replacement: 步骤 2 中的图像 1,1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Speaker Replacement, Speaker: 步骤 3 中的图像 1,3 Lenovo ThinkPad T495 Speaker Replacement, Speaker: 步骤 3 中的图像 2,3 Lenovo ThinkPad T495 Speaker Replacement, Speaker: 步骤 3 中的图像 3,3
    • Grip the speaker cable as close as possible to its motherboard plug, and pull directly backwards, parallel to the motherboard, until the plug releases.
  4. Lenovo ThinkPad T495 Speaker Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad T495 Speaker Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the three 1.6 mm screws.
    • Holding both sides, lift the speaker up and out.
结论
Christian Taylor
于03/28/22注册
523 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-6, Petersen Spring 2022 UMass Dartmouth, Team 1-6, Petersen Spring 2022 的会员
UMASSD-PETERSEN-S22S1G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 424
