跳转到主内容
Lenovo ThinkPad T495 Battery Replacement
你所需要的
  1. Lenovo ThinkPad T495 Battery Replacement, Baseplate: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Battery Replacement: 步骤 2 中的图像 1,1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four screws securing the battery.
    • On both sides of the plug, use your fingernails to "walk" out the battery cable connector until it releases.
  4. Lenovo ThinkPad T495 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the battery by lifting it up and out with your fingers
    • The battery should lift out with no resistance. If you feel any resistance, double check that the screws are removed, and that the connector is released from the motherboard.
结论
Christian Taylor
于03/28/22注册
523 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-6, Petersen Spring 2022 UMass Dartmouth, Team 1-6, Petersen Spring 2022 的会员
UMASSD-PETERSEN-S22S1G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 67
过去 30 天: 221
总计 4,012
