简介
If you've had a Lenovo ThinkPad T495 for a while, the battery may have degraded over time, as all lithium batteries do. If you have had your computer for a long time, or if you've constantly charged charged your battery then it may not last a long time anymore. If this is the case, then it is time to replace your battery. In this guide, you will be walked through the steps to do this.
你所需要的
Use a Phillips #00 screwdriver to remove the four screws securing the battery.
On both sides of the plug, use your fingernails to "walk" out the battery cable connector until it releases.
