此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
要重新组装设备,请按相反顺序执行这些说明。
请将你的电子废弃物送往 R2 或 e-Stewards 认证的回收商。
维修未按计划进行?尝试进行一些 基本故障排除,或者向我们的 Answers 社区寻求帮助。
另外一个人完成了本指南。
3指南评论
Hi Sanjay, we just want to make sure that there is no power to the system and the step to remove the battery is included as a precaution. Typically, you could detach the connector from the motherboard without removing the battery, and that would be sufficient. This connector is integrated into the battery case so we recommend battery removal. Thanks!
For ThinkPads, you can also disable the built-in battery in the BIOS settings before opening up the laptop. (You can always check if this is working by trying to turn on the laptop afterwards.) The internal battery stays off until you plug in the laptop with its wall charger again. This is shown in this video of the T480s (timestamped), before opening up the laptop.
