跳转到主内容
Lenovo ThinkPad T470S Wi-Fi Card Replacement
你所需要的
  1. Lenovo ThinkPad T470S Wi-Fi Card Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470S Wi-Fi Card Replacement, Wi-Fi Card: 步骤 2 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the Wi-Fi card.
    • The Wi-Fi card will lift to a slight angle after the screw is removed.
  3. Lenovo ThinkPad T470S Wi-Fi Card Replacement: 步骤 3 中的图像 1,1
    • Grip the Wi-Fi card on both sides, then pull it directly out of its port.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 44
总计 1,060
