简介
There are two batteries in the Lenovo ThinkPad T470S. We will show you how to replace both of them in this guide. The batteries need to be replaced if your computer isn’t holding a charge or only works when connected directly to power. This repair should be quick and easy as long as you have the batteries for replacement.
你所需要的
Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
Lift the bottom panel up and off the laptop.
Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
Peel back connecting supporting tape on each of the batteries.
7等其他人完成本指南。
一条评论
Is the rear battery, battery 1 or 2? It's my battery 2 that won't charge any more. But maybe I should just change them both. Do you sell both of them or just the one?
