跳转到主内容
Lenovo ThinkPad T460s Heatsink Replacement
你所需要的
  1. Lenovo ThinkPad T460s Heatsink Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Heatsink Replacement: 步骤 2 中的图像 1,1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Heatsink Replacement: 步骤 3 中的图像 1,1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Heatsink Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T460s Heatsink Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T460s Heatsink Replacement: 步骤 4 中的图像 3,3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s Heatsink Replacement, Heatsink: 步骤 5 中的图像 1,3 Lenovo ThinkPad T460s Heatsink Replacement, Heatsink: 步骤 5 中的图像 2,3 Lenovo ThinkPad T460s Heatsink Replacement, Heatsink: 步骤 5 中的图像 3,3
    • Remove the fan power cable in red square first.
    • Loosen all four 5.5mm Phillips #1 screws marked in red circle to take off the Radiator Assembly.
    • Those 4 screws can't be removed since all the screws have a retainer from the back
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 44
总计 2,397
