简介
Use this guide to replace the LCD bezel assembly on your Lenovo ThinkPad T460 laptop.
The screen bezel assembly comprises two parts: a thin LCD bezel sheet secured to the laptop with adhesive and the plastic border secured to the laptop with screws and clips. The LCD bezel assembly covers the internal components within the screen assembly including the WLAN and WWAN antennas and camera/microphone module. You may need to replace your screen bezel if it is cracked or damaged. Be sure to clean any remaining adhesive on the display assembly and reapply fresh adhesive when installing a new display bezel for best results.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
你所需要的
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Remove the two 3.7 mm screws from the LCD cable bracket using a Phillips #1 screwdriver.
Use your hands to peel up the thin LCD bezel sheet from the rest of the display, starting in the area between the hinges.
Use your hands to continue peeling the bezel sheet away from the left side of the laptop.
