简介
Use this guide to replace the hard drive in your Lenovo ThinkPad T460 laptop.
A hard drive (also known as a hard disk drive, HDD, or hard disk) is a storage component in a computer. Hard drives use spinning disks and moveable parts, as opposed to the flash memory used in an SSD. Signs of a failing hard drive may include clicking or grinding noises, disappearing data, computer crashes, and an inability for your computer to recognize the hard drive.
If you are able to recover any data saved to your hard drive, be sure to back up your files before beginning this guide. Also, make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
你所需要的
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Remove the single 3.7 mm screw from the left side of the hard drive using a Phillips #1 screwdriver.
3等其他人完成本指南。
