简介
This guide requires some caution when removing the cables connected to the wireless adapter. Use a spudger and avoid using tweezers with metallic points as it could damage the cable. The remainder of the guide is simple and requires unscrewing a screw.
你所需要的
Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
Use the spudger to remove the two cables that are connected to the wireless adapter.
另外一个人完成了本指南。
