跳转到主内容
Lenovo ThinkPad T440p Display Replacement
你所需要的
  1. Lenovo ThinkPad T440p Display Replacement, Display: 步骤 1 中的图像 1,2 Lenovo ThinkPad T440p Display Replacement, Display: 步骤 1 中的图像 2,2
    • Flip the laptop over so that the bottom of the laptop is facing you.
  2. Lenovo ThinkPad T440p Display Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad T440p Display Replacement: 步骤 2 中的图像 2,2
    • Slide each of the battery latches away from each other into the unlocked location.
  3. Lenovo ThinkPad T440p Display Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad T440p Display Replacement: 步骤 3 中的图像 2,2
    • Slide the battery out of the battery compartment.
  4. Lenovo ThinkPad T440p Display Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad T440p Display Replacement: 步骤 4 中的图像 2,2
    • Flip the laptop over so that the top of the laptop faces you.
  5. Lenovo ThinkPad T440p Display Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad T440p Display Replacement: 步骤 5 中的图像 2,2
    • Lift the lid of the laptop until the top of the lid is touching the ground.
  6. Lenovo ThinkPad T440p Display Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad T440p Display Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad T440p Display Replacement: 步骤 6 中的图像 3,3
    • Carefully pry the display bezels away from the display using the plastic opening tool.
    • The edges on the underside of the bezel that touches the display may be sharp.
  7. Lenovo ThinkPad T440p Display Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad T440p Display Replacement: 步骤 7 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the four 3mm display screws.
  8. Lenovo ThinkPad T440p Display Replacement: 步骤 8 中的图像 1,1
    • Carefully lift the display up and place it on the keyboard.
    • Don't remove it from the laptop. There's a cable still attached to it.
  9. Lenovo ThinkPad T440p Display Replacement: 步骤 9 中的图像 1,3 Lenovo ThinkPad T440p Display Replacement: 步骤 9 中的图像 2,3 Lenovo ThinkPad T440p Display Replacement: 步骤 9 中的图像 3,3
    • Locate the latch attached to the display cable.
    • Grab the latch and flip it over so that it is facing away from you.
  10. Lenovo ThinkPad T440p Display Replacement: 步骤 10 中的图像 1,1
    • Gently remove the cable from the display by pulling it directly away from you.
  11. Lenovo ThinkPad T440p Display Replacement: 步骤 11 中的图像 1,2 Lenovo ThinkPad T440p Display Replacement: 步骤 11 中的图像 2,2
    • Remove the display from the computer.
结论
5等其他人完成本指南。
Rasheed Adam
于07/27/20注册
337 声望
撰写一个指南
团队
UW Tacoma, Team S1-G19, Cardinal Summer 2020 UW Tacoma, Team S1-G19, Cardinal Summer 2020 的会员
UWT-CARDINAL-SU20S1G19
1 名成员
创作了1篇指南
2条评论
Easy peasy! Got a fresh 1080p IPS display into my ThinkPad thanks to this guide!
Noah - 回复
What display did you have before? I have heard that there are two different display cables and if you didn't already have a 900p screen/already had a 768p screen, then you will need a new display cable to do the FHD display swap.
Annika Genisis -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 78
总计 3,154
