简介
The back cover is the protective layer for your computer that covers many components that will likely be replaced. The process is very simple and you will only need to remove two screws with a Phillips #1 screw driver.
你所需要的
Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
即将完成!
结论
另外一个人完成了本指南。
