跳转到主内容
Lenovo ThinkPad T431S Screen Replacement
你所需要的
  1. Lenovo ThinkPad T431S Screen Replacement, Screen: 步骤 1 中的图像 1,2 Lenovo ThinkPad T431S Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use the Jimmy tool to remove the screen bezel with a gentle prying motion.
  2. Lenovo ThinkPad T431S Screen Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad T431S Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the four 3.0 mm screws in the four corners of the screen with a Phillips #1 screwdriver bit.
    • While removing the screws, pry the screen off with an opening tool.
    • If your screen is cracked, use caution, as there will be broken glass or sharp parts.
  3. Lenovo ThinkPad T431S Screen Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad T431S Screen Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad T431S Screen Replacement: 步骤 3 中的图像 3,3
    • Lift screen off of top panel to reveal LCD power plug/connector.
    • There will be a wire attaching the screen to the rest of the device.
    • Remove the tape on the wire so you can unplug the connection, pulling upwards.
    • Information about disposal of your damaged screen can be found at E-Waste Recycling
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 924
