跳转到主内容
Lenovo ThinkPad T431S Hard Drive Replacement
你所需要的
  1. Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 3,3
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver to remove the eight 5.0 mm screws from the panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Hard Drive Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T431S Hard Drive Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T431S Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the single 3 mm screw holding hard drive bracket in place.
    • Grasp the hard drive and remove it from its bracket.
    • Use a slight wiggle motion to carefully disconnect it from the front prong.
结论
2等其他人完成本指南。
一条评论
Can I add SSD without removing HDD? in Lenovo T431s?
Usama Khan - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 17
总计 589
