跳转到主内容
Lenovo ThinkPad T431S Fan Replacement
你所需要的
  1. Lenovo ThinkPad T431S Fan Replacement, Fan: 步骤 1 中的图像 1,2 Lenovo ThinkPad T431S Fan Replacement, Fan: 步骤 1 中的图像 2,2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • Carefully pry off the back panel using the opening tool.
  2. Lenovo ThinkPad T431S Fan Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad T431S Fan Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver bit and remove the four 3.0 mm screws from the heatsink.
  3. Lenovo ThinkPad T431S Fan Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad T431S Fan Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad T431S Fan Replacement: 步骤 3 中的图像 3,3
    • Disconnect the cable attached to the fan, pulling the connector straight down.
    • Lift and remove the fan.
结论
2等其他人完成本指南。
一条评论
Well done. I will have a go at fixing the fan on my T430s now that I’ve seen how easy it is to do.
Jocko - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 7
总计 329
