跳转到主内容
Lenovo ThinkPad T431S Charging Port Replacement
你所需要的
  1. Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,2 Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: 步骤 1 中的图像 2,2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Charging Port Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad T431S Charging Port Replacement: 步骤 2 中的图像 2,2
    • Unscrew the single, 3.0 mm screw with a Phillips #1 screwdriver bit that holds the charging port housing into place.
  3. Lenovo ThinkPad T431S Charging Port Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad T431S Charging Port Replacement: 步骤 3 中的图像 2,2
    • Remove the small, white connector cable by prying it from the connector with a plastic opening tool.
    • Remove the charging port assembly.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 23
总计 4,056
