跳转到主内容
Lenovo ThinkPad T431S Battery Replacement
你所需要的
  1. Lenovo ThinkPad T431S Battery Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo ThinkPad T431S Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remember, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off before starting any disassembly.
    • Use a Phillips #1 screwdriver bit to remove the eight 5mm screws from the back panel.
    • Once the screws are loose, use the three opening tools to loosen and remove the back panel.
  2. Lenovo ThinkPad T431S Battery Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T431S Battery Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T431S Battery Replacement: 步骤 2 中的图像 3,3
    • Carefully unplug the battery cable from the connector on the motherboard, using your fingers to pull the cable straight out of the port.
  3. Lenovo ThinkPad T431S Battery Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad T431S Battery Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad T431S Battery Replacement: 步骤 3 中的图像 3,3
    • Unscrew the five 4mm screws that are holding the battery secure with a Phillips #1 screwdriver.
    • Remove the Li-polymer battery by lifting it directly out of the device.
    • Information about disposal of your damaged battery can be found at E-Waste Recycling
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 1,220
