跳转到主内容
Lenovo ThinkPad T430s Keyboard Replacement
你所需要的
  1. Lenovo ThinkPad T430s Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo ThinkPad T430s Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo ThinkPad T430s Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Flip the ThinkPad right side up and open the lid.
    • Use the spudger to wedge the keyboard from the case.
  3. Lenovo ThinkPad T430s Keyboard Replacement: 步骤 3 中的图像 1,1
    • Lift the keyboard with your hands.
    • Pry the keyboard ribbon up from the motherboard with the flat end of the spudger.
    • Lift the keyboard from the case and find the ribbon press connector.
  4. Lenovo ThinkPad T430s Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use the spudger to lift the bottom right angle of the connector.
    • Remove the disconnected keyboard from the case.
结论
Cleophas Johnson III
于02/21/23注册
97 声望
撰写一个指南
一条评论
Do not forget to remove the screws in the memory and battery areas, if you don't the keyboard will NOT come off at all and you will most likely break your device.
Tenzin - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 63
总计 844
