跳转到主内容
Lenovo ThinkPad T430s Display Replacement
你所需要的
  1. Lenovo ThinkPad T430s Display Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo ThinkPad T430s Display Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo ThinkPad T430s Display Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Display Replacement, Display: 步骤 2 中的图像 1,3 Lenovo ThinkPad T430s Display Replacement, Display: 步骤 2 中的图像 2,3 Lenovo ThinkPad T430s Display Replacement, Display: 步骤 2 中的图像 3,3
    • Rotate your ThinkPad so the back side faces you.
    • With the Phillips #1 screwdriver, remove the two 70 mm screws in the right and left corners. These may be covered by plastic covers.
    • Open the ThinkPad so the screen faces up. Lift the screen from its hinges.
  3. Lenovo ThinkPad T430s Display Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad T430s Display Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad T430s Display Replacement: 步骤 3 中的图像 3,3
    • With the Phillips #0 screwdriver, remove the two 50 mm screws securing the plastic display case.
    • Wedge the flat end of the spudger in between the display case and the screen. Unsnap the top case from the bottom piece holding the screen.
    • Remove the case and set it aside.
  4. Lenovo ThinkPad T430s Display Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T430s Display Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T430s Display Replacement: 步骤 4 中的图像 3,3
    • Unscrew the four 30 mm screws holding the screen to the case.
    • Lift the screen out of the case.
    • Flip the screen over.
  5. Lenovo ThinkPad T430s Display Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad T430s Display Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad T430s Display Replacement: 步骤 5 中的图像 3,3
    • Peel away the tape holding the cable down with the flat end of the spudger.
    • Pull the cable out of its socket.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 13
过去 30 天: 63
总计 2,478
