跳转到主内容
Lenovo ThinkPad T410s Keyboard Replacement
你所需要的
  1. Lenovo ThinkPad T410s Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over.
    • Push and hold the locking switch to the left.
    • Pull the battery out with your other hand.
  2. Lenovo ThinkPad T410s Keyboard Replacement, RAM: 步骤 2 中的图像 1,2 Lenovo ThinkPad T410s Keyboard Replacement, RAM: 步骤 2 中的图像 2,2
    • Remove the single Phillips #0 screw grin the back panel.
    • Pull the back panel off.
  3. Lenovo ThinkPad T410s Keyboard Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad T410s Keyboard Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad T410s Keyboard Replacement: 步骤 3 中的图像 3,3
    • Pull the metal prongs at the side of the RAM away from each other.
    • The RAM will pop out of its socket when done correctly.
    • Pull the RAM out.
  4. Lenovo ThinkPad T410s Keyboard Replacement, Hard Drive: 步骤 4 中的图像 1,2 Lenovo ThinkPad T410s Keyboard Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Remove the single Phillips #0 screw that secures the hard drive cover.
  5. Lenovo ThinkPad T410s Keyboard Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad T410s Keyboard Replacement: 步骤 5 中的图像 2,2
    • Flip the black plastic tab out.
  6. Lenovo ThinkPad T410s Keyboard Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad T410s Keyboard Replacement: 步骤 6 中的图像 2,2
    • Pull the hard drive out.
  7. Lenovo ThinkPad T410s Keyboard Replacement, Keyboard: 步骤 7 中的图像 1,1
    • Remove the Flathead 2.5mm screw.
  8. Lenovo ThinkPad T410s Keyboard Replacement: 步骤 8 中的图像 1,2 Lenovo ThinkPad T410s Keyboard Replacement: 步骤 8 中的图像 2,2
    • Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
  9. Lenovo ThinkPad T410s Keyboard Replacement: 步骤 9 中的图像 1,2 Lenovo ThinkPad T410s Keyboard Replacement: 步骤 9 中的图像 2,2
    • Slide the keyboard out of the way until you can see what's underneath it.
    • The keyboard is still attached with a ribbon cable so don't try to fully remove it.
  10. Lenovo ThinkPad T410s Keyboard Replacement: 步骤 10 中的图像 1,1
    • Use the flat end of a spudger to unplug the keyboard connector from the laptop.
    • Pull the keyboard out.
结论
Blake Wilson
于02/21/18注册
117 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 36
总计 2,664
