跳转到主内容
Lenovo ThinkPad T400s LCD Screen Replacement
你所需要的
  1. Lenovo ThinkPad T400s LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Use a #0 Phillips head screwdriver to remove the two 3mm screws that hold the screen bezel in place.
  2. Lenovo ThinkPad T400s LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Using the plastic opening tool, gently pry off the plastic LCD screen frame around the entire perimeter.
    • Be careful while prying the frame off, because the plastic tabs that hold it in may break.
  3. Lenovo ThinkPad T400s LCD Screen Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad T400s LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the LCD connector by pulling on the ribbon cable at the connection.
  4. Lenovo ThinkPad T400s LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Lift the LCD screen out to replace.
    • Make sure to remove the screen with both hands and from opposite edges of the screen.
结论
7等其他人完成本指南。
团队
Cal Poly, Team 6-18, Maness Spring 2015 Cal Poly, Team 6-18, Maness Spring 2015 的会员
CPSU-MANESS-S15S6G18
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 2,534
