跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad T14 Gen 7 Fan Replacement
你所需要的
  1. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,2 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,2
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
  2. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Loosen the base cover screws: 步骤 2 中的图像 1,2 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Loosen the base cover screws: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
  3. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the base cover: 步骤 3 中的图像 1,3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the base cover: 步骤 3 中的图像 2,3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the base cover: 步骤 3 中的图像 3,3
    • The base cover is still lightly clipped to the laptop.
    • Use your fingers to grab and lift the top-right corner of the base cover near the hinge.
    • Repeat at the top-left corner.
  4. Lenovo ThinkPad T14 Gen 7 Fan Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T14 Gen 7 Fan Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T14 Gen 7 Fan Replacement: 步骤 4 中的图像 3,3
    • Slowly lift the hinge edge of the base cover until the remaining clips release.
    • Remove the base cover.
    • During reassembly, align the base cover's bottom edge tabs with the laptop, then lay the cover in place. Press around the perimeter to clip the base cover to the laptop.
  5. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Disconnect the battery: 步骤 5 中的图像 1,3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Disconnect the battery: 步骤 5 中的图像 2,3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Disconnect the battery: 步骤 5 中的图像 3,3
    • Use your fingers to squeeze the two latches on either side of the battery connector.
    • While squeezing the latches, lift the top edge of the battery up.
  6. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the battery: 步骤 6 中的图像 1,2 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the battery: 步骤 6 中的图像 2,2
    • Remove the battery.
  7. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Detach the fan: 步骤 7 中的图像 1,3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Detach the fan: 步骤 7 中的图像 2,3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Detach the fan: 步骤 7 中的图像 3,3
    • Use tweezers or your fingernails to gently push the fan connector out of its socket to disconnect it.
  8. Lenovo ThinkPad T14 Gen 7 Fan Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips screwdriver to loosen the three captive screws securing the fan.
  9. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the fan: 步骤 9 中的图像 1,2 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the fan: 步骤 9 中的图像 2,2
    • Lift and remove the fan.
结论
Arthur Shi
于01/03/18注册
334,349 声望
创作了847篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 117
总计 659
