跳转到主内容
Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement
你所需要的
  1. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: 步骤 1 中的图像 1,2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: 步骤 1 中的图像 2,2
    • Remove the 8 screws that hold down the back panel using the Phillips #000 screwdriver.
  2. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the two M2 x 3 mm, wafer-head, nylon-coated screws that hold down the hard drive assembly using the Phillips #0 screwdriver.
  3. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 步骤 3 中的图像 1,1
    • Pull the hard drive assembly out with backside up.
  4. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the four M3 x 3 mm, flat-head, nylon-coated screws on the side of the hard drive assembly using the Phillips #0 screwdriver.
  5. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 步骤 5 中的图像 1,1
    • Gently, remove the plastic cover with the blue strips.
  6. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: 步骤 6 中的图像 1,2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: 步骤 6 中的图像 2,2
    • Remove the 3 screws holding down the T shaped cover using the Phillips head #1. Two of the screws are M2.5x 4 wafer head. The other is a M2x4MM.
    • The two similar screws have blue threading around them.
  7. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 步骤 7 中的图像 2,2
    • Use the opening tool to lift up the T shaped cover.
    • Remove the M2x3MM wafer head screw.
  8. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 步骤 8 中的图像 1,3 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 步骤 8 中的图像 2,3 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 步骤 8 中的图像 3,3
    • Take off the 2 M2x3MM wafered screws holding down the chip top of assembly.
    • Lift the chip to release the HDMI-USB jack assembly
  9. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 步骤 9 中的图像 1,1
    • Detach the connector.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 295
