跳转到主内容
Lenovo ThinkPad P52s WiFi Card Replacement
你所需要的
  1. Lenovo ThinkPad P52s WiFi Card Replacement, Disable Internal Battery: 步骤 1 中的图像 1,1
    • Interrupt startup by hitting enter, and enter the BIOS by hitting F1.
    • Navigate to Config -> Power, and disable the internal battery.
  2. Lenovo ThinkPad P52s WiFi Card Replacement, Remove Detachable Battery: 步骤 2 中的图像 1,1
    • Close the lid and flip the unit over. Pull the battery release tabs outwards, then pull the battery out.
  3. Lenovo ThinkPad P52s WiFi Card Replacement, Remove Bottom Plate: 步骤 3 中的图像 1,1
    • Unscrew the bottom plate.
    • Starting from the corners further from the hinges, carefully run the spudger around the machine releasing the clips holding the bottom plate in place.
  4. Lenovo ThinkPad P52s WiFi Card Replacement, Replace WiFi Card: 步骤 4 中的图像 1,1
    • Locate the WiFi card, and gently remove the two antenna cables.
    • Remove the screw holding the card in place, and pull the card out. Replace it with the new one.
    • Plug the antenna cables into the new card. The gray one is the main antenna (indicated by solid triangle) and black the auxiliary (indicated by empty triangle).
结论
另外一个人完成了本指南。
Prithvi Vishak
于04/04/22注册
141 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 36
总计 1,135
