跳转到主内容
Lenovo ThinkPad P52 Keyboard Replacement
你所需要的
  1. Lenovo ThinkPad P52 Keyboard Replacement, Remove track pad click covers: 步骤 1 中的图像 1,1
    • The first step is to remove the track pad left and right click covers. I used a plastic spudger tool to carefully pry and remove.
  2. Lenovo ThinkPad P52 Keyboard Replacement, Loosen screws holding keyboard in: 步骤 2 中的图像 1,1
    • Once you have removed the covers you will see two screws (one on each cover). Using a PH0 screw driver, loosen the screws (they are attached so will not come out).
  3. Lenovo ThinkPad P52 Keyboard Replacement, Remove keyboard: 步骤 3 中的图像 1,2 Lenovo ThinkPad P52 Keyboard Replacement, Remove keyboard: 步骤 3 中的图像 2,2
    • Once the screws are loose, you can push the keyboard up to release the tabs holding it on on the bottom. I use a spudger to assist with this.
    • Once the tabs are released, you can carefully pull the keyboard down and flip it towards you. Exposing the two cables connecting it to the motherboard.
  4. Lenovo ThinkPad P52 Keyboard Replacement, Unplug ribbon cable: 步骤 4 中的图像 1,1
    • Using a plastic spudger, release the clips holding the cable ribbons on.
    • Remove cable ribbons and keyboard has now been removed.
  5. Lenovo ThinkPad P52 Keyboard Replacement, Insert new Keyboard: 步骤 5 中的图像 1,3 Lenovo ThinkPad P52 Keyboard Replacement, Insert new Keyboard: 步骤 5 中的图像 2,3 Lenovo ThinkPad P52 Keyboard Replacement, Insert new Keyboard: 步骤 5 中的图像 3,3
    • The new keyboard can be attached by running these steps in reverse.
    • First attach ribbon cable
    • The fold keyboard into laptop starting at top and then clip in towards bottom by pulling it down.
    • Then tighten the screws under the left and right click covers
    • Then attach the covers
结论
Bill
于09/17/14注册
818 声望
创作了5篇指南
2条评论
This isn’t for the P52s….
James Liu - 回复
Thank you. It is for the P52 model. I don’t know if the P52s is the same as the P52 as far as replacing the keyboard but when I was making the article it auto-populated the P52s and I didn’t change it back. I have made the appropriate change.
Bill -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 23
过去 30 天: 101
总计 5,743
